Brick facade repair methodology
Have been asked to evaluate an ongoing facade repair project, which requires removal of veneer along the floor slab edges for shelf angle and flashing repairs. I observed that the contractor is supporting brick above areas of removal with short 2x4 "cripples" spaced 3 to 5 feet apart, and my experience tells me this is inadequate. I typically require the use of structural steel plates or angles and screw-jacks or hydraulic jacks. QUESTION: Does anyone know of a generally accepted or documented standard that would apply to this case. It would be preferable to reference a documented standard that any qualified contractor should use as a guide.
RE: Brick facade repair methodology
Ron, BIA was among the first sources we checked. No dice. Thanks for the suggestion anyway...
