Pressure Change Due to Piping Length
3
DILEMMA
Because the length of piping and no other variables are changing, I am looking for a basic formula for determining the additional pressure change, as it relates to additional pipe length.
BACKGROUND
I am doing a basic, dual-phase vacuum process.
There are times when the process is only removing ambient air and minor levels of vapors.  There are also times when the dual-phase is operating and water is also being removed.
I need to perform the same task, at an alternate location, on the site.  The only variable that is changing is the necessary length of the 1" ID plastic tubing.
RE: Pressure Change Due to Piping Length
Do you have Crane #410 (Flow of Fluids)?  Page 2-8 discusses how to figure pressure drop in straight runs of pipe..
Patricia Lougheed
I do not have this document.
Is this publicly available or something that must be purchased?
You have to buy Crane - it's about $30 and can be ordered over the web at:  http://www.vervante.com/crane/ .  I highly recommend getting a copy of this if you're going to be doing any work with fluid flow.
I'll try to condense the basics here, but I need to warn you I may be leading you astray...I'm a nuclear engineer and picked up my fluid flow knowledge over the years.  Also I've only worked with water systems so don't know how two-phase flow affects the pressure drop and what limitations you have on it.
Basically the head loss (h) (or pressure drop) is a function of the (1) roughness of the pipe (f) , (2) length of pipe (L), (3) diameter of pipe (D) and (4) velocity of the fluid through the pipe (v).
formula is h=f*L/D*(v^2)/2g for non-compressible fluids
For compressible fluids (such as air and vapor), the formulae change with the amount of pressure drop expected.  If the pressure drop is fairly small (you're not adding a whole lot of piping), you can use the above formula.  If it's large, then the formulas get complicated.
If you're looking for more than a rough answer, it might be worthwhile to hire someone who knows about this.
Patricia Lougheed
