Simplified Layer and Lineweight Standards for Civil Eng.
Can anybody suggest or refer me to a simplified layer and lineweight standard for preparing AutoCAD drawings for a geotechnical engineering firm?  I know that there is an architectural standard for AutoCAD drawing layers, but it is probably way too complicated for our purposes.  It has to be simple, because nobody in our office is a draftsman, and I have a heck of a time just trying to get our younger engineers to follow drafting conventions such as not crossing a dimension line, making text size consistent, not exploding dimensions, and my favorite, drawing to true scale.  Thank you for your replies
RE: Simplified Layer and Lineweight Standards for Civil Eng.
Sounds to me that you should hire an ACAD checkperson to set your young engineers on the right path.
I use a modified AIA naming scheme... and would have C-SOIL-OUTL,  C-SOIL-PATT, and  C-SOIL-HDDN for outline, pattern and hidden, resp. The pattern would depend on the type of soil encountered.  Line weights (ie. colour) would vary.  I also use layers C-FNDN-OUTL,  C-FNDN-PATT, and  C-FNDN-HDDN for foundation information where again the PATT would be for steel, concrete, timber, etc.
give your brightest, most motivated, cadd savvy young engineer the task of writing the office standard. After reviewing and approving the standard, make everybody use it.
