ASME Section 8, Div. 1 Design
As an ASME Sect. 8, Div. 1 manufacturer must our designers be PE's? Is there an answer to this in the ASME Code or the NBIC?
RE: ASME Section 8, Div. 1 Design
There is no Registered Professional Engineer requirement in ASME Section VIII, Division 1.  However, depending on your location, there may (or may not) be a prior determination about whether or not designing these pressure vessels constitutes the practice of engineering, and therefore requires one to be a Professional Engineer.  Also, some pressure equipment jurisdictions may require a Professional Engineer to certify all or part of the design.  However, there are many such Professionals available for hire.
