Corrosion rate
Corrosion rate
Corrosion rate
I'm looking for corrosion rates (data) of DEPG (Dimethyl ethers of polyethylene glycol) Vs. CS.
Any links will be greatly appreciated.
RE: Corrosion rate
Thanks strider6.
I do own CorSur and I found C2H6O (Dimethyl ether). will it behave similar to DEPG?
RE: Corrosion rate
Look for MSDS CAS Number: 24991-55-7.
Cheers,
gr2vessels
