Modifing A Composite Curve???????????
Good morning, I have discovered a small problem and I am not sure if there is any way to fix it other than to delete it. I have a profile on a plane and I turned it into a composite curve and then I created several profiles and attach them to the composite curve and all was well. Then I had to modify then original profile of the composite curve and everything attached to the curve appeared to move correctly and I was happy. Then I save the part and I went back into it and everything was sitting were it was in the original composite curve. If I delete the original composite curve, all of my relationship go with them and there are a lot of them. So the twenty dollar question is, is there a way to modify a composite curve's profile so the composite curve can be modified? I hope I have made myself clear here and I how that someone knows how to modify a composite curve. Thanksn in advance.
RE: Modifing A Composite Curve???????????
I have a profile sketch which used for the composite curve. After saving I can modify the underlying sketch and the composite curve modified as well. I have reopened the part several time but all OK.
Have you tried to repeat your steps? And check the issue on different machine?
Artem
