Noisy gear pump
Noisy gear pump
I have a gear pump installed pumping diesel oil. Specifically it is a Viking HJ4195 running at 1450rpm (4pole 50Hz supply) at 66psi delivery pressure. The suction is supplied wth a head of about 6ft plus and we have checked the pressure at the inlet port during operation and it is 5psi or higher depending on liquid level in the fuel tank.
The pump is a new installation and has been noisy (sounds like a bag of old bolts...grinding raspy sound)from the start. I have had the supplier look at it and they are at a loss. A new pump was supplied last week and after installation and alignment it was just the same.
Just a few more notes:
1) Pump alignment is OK
2) Current draw is fine and pump is free and its own bearigs OK.
3) Motor is new, bearings fine and runs separately smoothly.
4) Going on inlet pressure measurement does not appear to be a cavitation or NPSH problem
5) Internal relief valve is not operating as pressure is set by external pressure regulator (returning to tank) and internal relief opens at about 85psi (delivery press 66psi).
6) The only thing I am considering is that the pump is installed with two 1-1/2" flexible connections (convoluted SS covered with braid about 12" long) see attached photo, to alleviate any piping stress on the pump. Could these be causing irregularities in the flow as the bore is not smooth as would be the case with rubber hose?
Has anyone had similar instances when using convoluted SS flex to supply pumps?
Any comments would be appreciated.
Thanks in advance,
Rod
Thanks in advance,
Rod
Rod Nissen.
Combustion & Engineering Diagnostics
RE: Noisy gear pump
Entrained air will generate the noise often associated with cavitation. Look for a leak on suction side of the pump- air can be drawn in-leak does not necessarily have to leak diesel.
Tom
RE: Noisy gear pump
I can't imagine any issues there. Having the diesel head on the pump, would expect a significant leak out of the suspected point of air ingress, especially when the pump is off, as it often is for extended periods. Also the pressure gauge readings on both inlet and outlet are dead steady.
Rod.
Rod Nissen.
RE: Noisy gear pump
Tom
RE: Noisy gear pump
Hopefully we can get to the bottom of this.
Standing wave/resonance? Any way to change the motor speed?
Keith Cress
RE: Noisy gear pump
No at present there is no way to change the speed. Lowering it would affect our required pump capacity.
Actually it is interesting that you ask, because when I have used these particular pumps in the past I have always opted for 6 pole motors (950rpm)to provide longevity due to lower sliding speeds. This time the capacity required meant I really had to choose a much larger pump to run at 950rpm or up the speed on a smaller one. However I have not used these convoluted SS flex for pump attachment before.
Rod
Rod Nissen.
RE: Noisy gear pump
I'm more experienced with refrigeration where those flexible coupling are very common and often required to prevent rapid fatigue failures. The compressors are mostly piston based positive displacement and cause even more pulsation than a gear pump could ever manifest. The flex connections tend to reduce noise not increase it. Of course I'm talking a compressible medium unlike your case, so...
Keith Cress
RE: Noisy gear pump
Rod
Rod Nissen.
RE: Noisy gear pump
For whatever reason I could not get your attachment to open yesterday at work. The SS hose you show is the same type we use for water evacuation on electric arc furnaces and ladle furnace applications(vacuum). They are bad about cracking and sucking air-when this happens we lose vacuum-no water is evacuated and the water cooled roof or sidewalls over-flow.
There is also a pipe union in your piping-NPT fittings should be avoided-especially the use of unions. Replacing this with a reinforced hose suitable for suction service hopefully will take care of your problem.
Tom
RE: Noisy gear pump
If the pump is running too fast or the fluid viscosity is too high then the pump will not be able fill properly and will go into cavitation which will be very loud.
Can you be sure that the hose has not blistered inside, choking the flow to the pump?
Adrian
RE: Noisy gear pump
No the pump operating conditions are all per manufacturer/ supplier. This pump has been noisy from day 1 when everything was new and the installatiopn is only a few weeks old now. As I said before, we have a significant suction head on the pump, have measured the inlet pressure during operation and it is above the NPSH required.
Rod Nissen.
RE: Noisy gear pump
RE: Noisy gear pump
Well "air" ingress has been mentioned before but as there is a significant head on the suction line I would expect an obvious leak to show up when the pump is off and exposed to this liquid head. In your case was there any show of oil coming out through the gland with the pump off?
Yes we have a strainer further back at the tank outlet. Just a single 3" Y-type fitted with a 80# screen.
I will however go over all possible leakage points again. May have to wait a few days as we have just been hit by heavy rain which is supposed to hang around till next week. This plant is out in the open.
Rod
Rod Nissen.
RE: Noisy gear pump
Ted
RE: Noisy gear pump
Well it sure sounds mechanical, but if you read my original post I have pretty much checked everything AND installed another new pump and the noise is the same. Tried the listening tricks and it appears to eminate from the pump. However cavitation too can sound very mechanical and/or air in the pump. I was also discounting those except muscovy's post seems very close.
I was wondering about the convoluted SS flex causing flow irregularities into the pump and hoping that someone may have had a similar experience.
Rod
Rod Nissen.
RE: Noisy gear pump
I don't understand how you're getting 5 psi at the inlet port of the pump when the static head of liquid is ~3psi.
Those convoluted flex connections may have an i.d. a bit smaller than pipe of the same size, and present an additional restriction proportional to the number of convolutions.
In the picture, that sure looks like undisturbed factory paint on the plug in the pressure test port of the pump body.
Have you got a compound gage you can trust to put in there to re-run the test yourself? Or a 2-meter stick and some transparent tubing from which to make a standpipe for checking the suction head at the pump inlet?
Mike Halloran
Pembroke Pines, FL, USA
RE: Noisy gear pump
Actually the tank static head on the pump can vary from 5ft to nearly 30ft of diesel, depending on how much they have in it. The highest I have seen is about 12ft. It makes no difference to the noise. The Required NPSH for this pump is 9.5Ft wg. The max flowrate is 15gpm (US). I have about 12ft equivalent length of 1-1/2" suction pipe. My estimation tells me I can suck a lot below the pump before I have a problem.
Why the paint is undisturbed is that this is the just fitted new pump which I haven't measured any suction pressures on. I measured it on the "old" new pump, but replacing it with the current pump produced no difference to the noise.
Spoke to the SS flex manufacturer today and he reckons he has never heard of a problem using these flexes on pump suctions.
Rod
Rod Nissen.
RE: Noisy gear pump
Ted
RE: Noisy gear pump
Do you mean the guard over the couplng? If so there are only a couple holding it down at present just to keep it safe. I have had it off and on regularly making sure the pump in not mechanically seizing up. The noise is the same whether it is in position or not!!
I will be back on site again next week but still not satisfied a rubber hose will fix the problem, unless it is some sort of pulse induced resonance with the inlet pipework. Will try wedging or propping the pipework to try and change its natural frequency.
Also will run the pump very briefly empty to see if it is an internal mechanical noise.
Rod.
Rod Nissen.
RE: Noisy gear pump
RE: Noisy gear pump
The external pressure regulator is a Jordan sliding gate back pressure regulator...probably the best type of valve for this application. I have used them exclusevely for years. The regulation is done with the lower edge of the sliding gate against the orifice. So there is no seat and lid as in a conventional valve to chatter if oversized or if just a PRV/PSV etc. I can shut this valve right off and then the internal relief of the pump opens ...basically the noise is still there. I am also confident that the pump internal relief is fully shut during normal operation.
Thanks for the input.
Rod
Rod Nissen.
RE: Noisy gear pump
Ted
RE: Noisy gear pump
Only valves on the suction side are a large 3" tank 1/4 turn ball valve before the strainer and another ball valve 1-1/2" before the pump inlet flex. The suction line is under tank head pressure (positive always). I will however try the light oil next time on site. Have to go work interstate till the weekend so only will be back there next week.
Thanks, Rod.
Rod Nissen.
RE: Noisy gear pump
I have not failed. I've just found 10,000 ways that won't work." — Thomas Edison
_____________________________________
RE: Noisy gear pump
Suspect that air may be trapped in any high points in the line such as the hose corregations. (especially if hose is arched/pocketed) If so, this air could be gradually fed to the pump over time.
It would also serve as a collection point for any entrained air to gather and do the same.
RE: Noisy gear pump
Went back and tried the oil over the spindle glands of both ball valves on the suction side. The oil just remained where it was, no sucking or reduction in pump noise. I am having some rubber hoses made up to try.
Thanks to all so far.
Rod
Rod Nissen.
RE: Noisy gear pump
I would consider using pulsation dampers at the pump suction and discharge ports. This would isolate the inertia of the fluid in the piping from the high frequency flow rate fluctuations that are a characteristc of this type of pump. The greater speed of the pump increases the effects of the inertia at a rate much beyond the speed ratio. Even though you may have enough nominal suction pressure, the instantaneous suction pressure may actually be greatly reduced.
