ProE Wildfire 4.0 configuration options not "applying"
Hi All,
(Wildfire 4.0, M020, Vista x64 ultimate)
I'm trying to change WF from imperial to metric as the default units (mm, kg & mks).
However whenever I try and set anything in tools->options, the Status icon is initially green, but when I press Apply it goes out (and the change doesn't go through). This happens both to the Current Session and %homepath%/config.pro (although the files are saved).
I've tried running ProE as Administrator with no change. I have looked far and wide - the help files only make passing references to the status icon, and my best google skills have not helped out so as my last port of call I hope a clever spark out there knows what is going on :)
RE: ProE Wildfire 4.0 configuration options not "applying"
Edit -> Setup -> Units
and change the units here, saving the part/assembly with the new setting.
Drawings was my primary goal in changing over (makes it so much easier to get the scale right)
Some people think it should come with all this stuff preset but then you would never spend the blood sweat & tears to learn how it all works.
