Vibration sensoring: What is significant ?
Hi there!
I am working on a Mesureing System for mechanical Vibrations. I will use an Accelerometer and process the data with LabView.
Through Integration i can get Velocity and Displacement, right ?
What is significant data or plots for a vibration ?
Can i mesure/calculate Frequency as well ?
Thnax Alex
Thnax Alex
RE: Vibration sensoring: What is significant ?
Thus, the accelerometer signal should be highpass filtered prior to integration. Preferably, the highpass filtering should be performed on the analog accelerometer signal, prior to digitization. However, the highpass filtering may be performed on the digital signal, if necessary.
A complete answer to your question is beyond the scope of a message board reply. I have posted some relevant software programs and tutorials on signal processing at:
http://www.vibrationdata.com
As disclosure, a very small fee is required to download the software and tutorials at this website.
Sincerely, Tom Irvine
