Copy Assembly with Drawing
I want to copy a drawing and assembly to a new location. In 2007, I could
-open the drawing
-click Save As
-change the location for the drawing file
-click References
-change the path for the assembly (and any other parts I want)
-click OK or Save (I don't remember now)
-click Save in the main Save As window
In 2009, I get to the References, and I can change the path for the assembly, but I only get a Save All button. Some of the assembly components are read only, so it does not go through.
As a workaround, I know I can
-Open the drawing
-click Save As
-check the Save as copy box
-click Save
-close the drawing
-open it in the new location
-open the assembly
-Save As the assembly to the new location
-go back and save the drawing
but it takes longer, and I always forget to close the drawing and reopen the copy. Also, if I want to copy other components to the new location, I have to save them all individually, and if other assemblies are open that use the components, the Save As can mess them up.
Any thoughts on how to proceed? Am I stuck with the awkward workaround? Why did they change the original functionality?
Steve
-open the drawing
-click Save As
-click References
-Open the drawing
-click Save As
-click Save
-close the drawing
-open the assembly
Steve
RE: Copy Assembly with Drawing
Any other suggestions would be appreciated.
Steve
Steve
Alternatively you can use the SolidWorks API. Please refer the "Copy Document and Its Dependencies Example (VB6)" sample in API Help.
Artem
Artem Taturevich
CSWP
