Retriving of unsaved part
Is it possible to retrive a part i can not save because of power problem or somthing like that.
Thanks in advance.
RE: Retriving of unsaved part
Not really.  The runtime data, including your model(s), are stored in 'virtual' memory and that's the problem, it's only 'virtual'.
If these power interruptions are a common occurrence, you really should invest in a UPS system, at least one that you could put on your workstation so that you would have a chance to save your files locally even if you're normally hooked to a server.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
