Weld overlay chemical analysys
Hi Dears
Please read the follow technical matter:
If we have cladded plate, we have to done weld overlay in junction.
for testing chemical composition of weld overlay ,in our specification, we have to take a sample from 3/4 weld overlay thickness. as you know generaly overlay THK. is greater than clad THK. and overlay THK. is not considered in design and calculation thereupon the thickness of base metal for equipment shall increase.
this subject have a huge cost for us!
-am I right?
-if the answer is not please tell me how i can abstain increasing of base metal thk?
thanks alot
-am I right?
thanks alot
RE: Weld overlay chemical analysys
are you saying that 1/8" nominal overlay has hot to be tested at 3/4 way down?
if so you would drill down 3/32" and take samples leaving 1/32 for dilution
most people do a thicker overlay than 1/8" say 3/16 for conversation sake.
you would drill your pqr chemical sample plate down the same 3/32 from surface leaving 3/32 for dilution
all production welds will have the same number of passes
I am assuming that these drilled samples are just for qualification and the production welds will be inspected by PMI
could be wrong though
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
Typically the chemistry has to be verified at a depth equal to the clad thickness. As you say normally the restoration at welds is thicker than the adjacent clad thickness. Using this criteria, if your clad is 1/8" thick you would test the restored area ( weld overlay ) at 1/8" below the surface.
My specification is asking for the same location of the sample for testing the ferrite content. The only different is that the required test to be done on a production test plate. Also, the same test was required in the WPS/PQR.
Honestly, I cannot imagine a Client to ask for damaging the completed welding and expecting rework with fully approved repair welding procedure...
Also, please read the ASME SA 264/265 and ASME VIII Div 1 for details of the inclusion of the cladding thickness in the pressure resisting thickness calculations.
Cheers,
gr2vessels
Plymouth Tube
