Comparing Brass and Duplex
Hi all
I have a question !
I want to know about corrosion resistance of naval and admiralty brass and Duplex materials.
can someone compare those two group?
I know that Temp. and media is important for corrosion ,but i want to compare them roughly!
thank you.
I have a question !
thank you.
RE: Comparing Brass and Duplex
rmw
and (H2,N2)
In your case, fluid with H2S, i'll select duplex, even if duplex has limits in terms of H2S partial pressure.
as rmw said you need to be more specific on operating conditioons and type of service.
S
Corrosion Prevention & Corrosion Control
You need to step back and start with some basic information and learn about these types of alloys.
Plymouth Tube
Our licensor in his material selection approved both Brass(Naval and Admiralty for some cases) and also Approved Duplex material instead them.
We want to buy those equipment(Shell and tube heat exchangers)and need some information to sellect Duplex or Brass base material.
