Datum Pattern Callouts
I have a part drawing that contains 6 sheets.
A pattern of 2 holes is called out as Datum B on Sheet 1.
I need to identify Datum B on the other sheets, but it's not necessary to callout the size of the holes. What is the proper way to do this (if there is a proper way)?
Do I need to callout the hole sizes every time?
Would it be ok to have a leader with "2x" and Datum B identifier attached to the leader?
RE: Datum Pattern Callouts
Peter Stockhausen
Senior Design Analyst (Checker)
Infotech Aerospace Services
Do you really have to repeat the datum id? I know we often do it for clarity and it's ok to do it, but in your case it seems it might make it more confusing.
KENAT,
Have you reminded yourself of FAQ731-376: Eng-Tips.com Forum Policies recently, or taken a look at posting policies: http://eng-tips.com/market.cfm?
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
In my case I have Datum B fully defined on Sheet 1, but the other sheets have features that reference datum B. So my plan was to identify datum B on every sheet, but only have it fully defined on Sheet 1. I figured this would keep things clear without redundantly defining the datum.
Normally we probably would repeat it on a second sheet to make it easier to read, but as I say, in your case it might add to confusion.
I certainly wouldn't expect it should be redefined as this requires double dimensioning.
KENAT,
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
