separate assembly window
Hi all,
I'm working in an assembly, putting parts together (Using ProE 2001). I'm using a separate window to show the part I'm adding. What will happen is every time I pull up a new part to assemble, the separate window will "flash" up on the screen, and disappear. I then have to deselect and reselect the icon to make that window appear. How do I get it to stay up there in the first place?
Thanks!!!
Pat
Thanks!!!
Pat
