Correlation between BSU & FSN
Is there any correlation between
1. BSU & FSN : Bosch Smoke Unit measured by Bosch hand pump & Filter Smoke Number measured by AVL 415.
2. AVL swirl index & Ricardo swirl index
RE: Correlation between BSU & FSN
in re q2:
I asked a friend of mine who is knowledgable in these matters, and he said that it depends on what you're trying to convert from.  If you have swirl measured over the whole lift event, then a Ricardo swirl number can be calculated from that.  If you have an AVL swirl number, it cannot be directly converted because the AVL number is based on a fraction of the lift event, while the Ricardo number is based on the entire lift event.
He said he'd try to find out if anyone had a nifty conversion table (or similar) to get you close.
There is a correlation between BSU & FSN.  I've found 5 different curve-fit equations relating the two (several from Ford, and some others).  Unfortunately, the information is all in reports marked "company confidential" so I can't share it unless I can track down a public source for the information.  I'll let you know if I find one.
