Hyperlinking in Solidworks Drawing
I am having a problem with Hyperlinking within the Solidworks Drawing.
We have standard parts which I have added to the Drawing Template via some hyperlinks, however when you start a new drawing using the template, the links are broken (it links to the main solidworks folder).
Same thing happens if you copy hyperlinks to another drawing sheet.
Interestingly when you check the link, the path is still correct only it doesn't link to the path it is specifying, just the solidworks folder.
Any ideas??
Thanks.
Any ideas??
Thanks.
RE: Hyperlinking in Solidworks Drawing
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
