5th axis required?
5th axis required?
I require 2 flat surfaces parallel to each other to be milled, with a straight sloped surface i.e. a long chamfer connecting the 2 planes. The surface finish is not critical on the sloped section and I can live with rads on the 2 corners. One machinist tells me this requires 5th axis, another doesn't. I would have though as long as the path of the tool is in straight line that this could be done without the need for a 5th axis machine. I've attached a sketch to illustrate the profile side on.
Just want to clarify if this does need 5th axis or not.
RE: 5th axis required?
Here's a pdf of a 3d model showing a tool and the blue faces are those to be machined, this is just indicative, I appreciate the tool is not very realistic.
Why not machine it with the tool in the red axis (x axis)?
Doing it the way you have it you will have a wierd radius on the inner edge of the sloped face.
see attached
Obviously if this is a 1 off there is no issues. But I would actually suggest them making the part in 2 steps if this is a production part. Run your top features, then turn the part. I bet it's faster n 2 steps depending on what you can live with as far as surface finish on the sloped plane.
If their CNC machine can actually turn the part (typically called an A axis I believe) during machining your even better.
.......which is exactly why I posted a 3d view with a mocked up cutter further down, see link above.
Larry
