Property text
Property text
Property text
When there is no reference to property text-field it comes out with error: no reference. Is is possible to change/remove this default. I would like it so that the field is blank when there is no data and that it shows the the data when there is data.
Here is the property text: %{mat_std|R1}
RE: Property text
You could put a space character in the file property instead of having nothing, or a "-" to show it's not defined.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
RE: Property text
That is one way to avoid it. I think i will use it for now. Thanks.
