Ansys CFX - memory problem
Hi !
I do the interaction beetwen fluid and structure. After I've started the analysis obtained the comment:
"This model requires more scratch space than available. ANSYS has currently allocated 542 MB and was not able to allocate enough additional memory in order to proceed. Please increase the virtual memory on your system and/or increase the work space memory and rerun ANSYS. Problem terminated".
I introduced in start110.ans:
NUMRESLT=100000
NUM_BUFR=32
SIZE_BIO=4194304
NUM_VPAG=8192
NUM_DPAG=131068
SIZ_VPAG=131072
but nothing has changed.
If you had similar problem and know what's wrong please help.
