two 4-20ma loop sources isolation
I want to transmit a 4-20ma valve position to a control system. However the CPT in the actuator supplies power to the loop and the control system I/O also supplies the loop. Neither can be changed without considerable expense. Is there any way of isolating the two loops or any opto isolators taht will take a powered loop on the input and output?
RE: two 4-20ma loop sources isolation
Yes there are some. I think Automation Direct FC-33 will do what you want.
Moore Industries also make one, but I dont have the model.
http://we
Roy
