Piping Question..
Piping Question..
As you can see from the jpeg, Im trying to use the "Swept Boss/Base" command to draw a pipe going both directions once it reaches the end, but the command wont let me. How do I draw a pipe going in both directions? Is there a command I should be using instead of the Swept Boss?
RE: Piping Question..
To create a branch or Tee, a second sweep is needed.
