Rotating problems.. (45 angle)
Ill try and describe this as best as I can.. If you look at the jpeg, Im trying to draw some pipe, and some of them are on 45 degree angles. On the left, I have a circle, and Im trying to rotate the circle 45 degrees so I can draw a pipe coming off that vertitcally at a 45. But when I rotate the circle 45 degrees, it doesnt do it properly.
Is there a way I can rotate the orgins easily so I can make 45 degree lines easier, or correctly draw circles at 45 degree angles?
RE: Rotating problems.. (45 angle)
-Dustin
Professional Engineer
Certified SolidWorks Professional
Certified COSMOSWorks Designer Specialist
Certified SolidWorks Advanced Sheet Metal Specialist
Basically, I have that pipe going off at a 45 degree angle, and Im trying to create another pipe going up vertically off that at a 45 as well. But when I rotate the circle 45 degrees, it does it at a weird angle.
Did you create the rest of the model? If you did, I don't understand how without having an understanding of planes.
Embarrassingly enough, to create the 45 degree angles, I just drew a line up 5 and over 5 and then connected it to make a 45 degree angle.
And obviously, Im sure theres a much easier way to do it.
Well, if it takes too long to explain how to create a plane, could you tell me which tutorial would be best in explaining what Im trying to do? And again, thanks for your help.
Go to Help > SolidWorks Help > Index > planes and follow all the associated links to get more details.
Take a look at the jpeg for examples... sorry if it's shrunk down too much. I'm sure the others can help guide you as well as the help file that CBL referenced.
