Parts and assemblies will open in seperate windows
Hola everyone,
Recently I have come across a bit of wierdness with Solidworks, and I have been unable to find an answer for why it is happening. Another user at my company has checked an assembly into PDMWorks, and when other users check this assembly out and open it, many of the part files and sub-assembly files will open in seperate windows. Does anyone have any ideas as to what could be causing this? We are using 2009 SP 3.0.
Aaron
SolidWorks/PDMWorks 09 3.0
CADKey 99 R1.0 (Yes, still using it!)
RE: Parts and assemblies will open in seperate windows
They probably have the Load referenced documents option set to All at Tools > Options > System Options > External References.
As usual Mr. Blimey, you are correct. We have been annoyed by this for a few weeks now. Thank you very much!
Aaron
