Convection Heat Transfer
For the purpose of convection Boundary condition, is it necessary to define the convection coefficient? I only have a time based value, but for some reason the program would not let me define a table of the convection coefficient.
Could anyone help
Could anyone help
RE: Convection Heat Transfer
Tobalcane
"If you avoid failure, you also avoid success."
It is not simple to find one single value for h. I am modelling a real test and have about 8000 values (over time) for the surface temperature!
Tobalcane
Nonetheless, if your analysis program does the FEA, then the effective htc should flow out of the analysis.
TTFN
