Requirement for HIC
Requirement for HIC
Requirement for HIC
As per NACE MR 0175/ISO 15156 clause 8,Conventional forgings with sulfur levels less than 0.025 %, and castings, are not normally considered sensitive to HIC or SOHIC.
         from this the interpretation is  that casting doesnt require HIC, Is the interpretation  correct , or really castings require HIC.
          thanks in advance for your reply
RE: Requirement for HIC
You have already asked this question in the corrosion engineering forum where you have several replies.
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
