H2SO4 especific and latent heat
Please  can give me such 2 values for
H2SO4 100%
especific heat
latent , or boiling heat .
Imperial or SI units , or whatever
RE: H2SO4 especific and latent heat
From Lange's Handbook of Chemistry:
Enthalpy of vaporization at boiling point: 50.2 kJ/mol
Specific heat, J/(K.mol), @ 400 K: 158.2; @ 600 K: 197.0
I hope I've read correctly the small printed figures.
Hi 25362 , could you give me the Boiling point for Sulphuric Acid?
I forgot to thank you.
Diverse data from different sources:
Lange's: 335.5oC
CRC: 337oC
Perry and J.T. Baker's MSDS: 340oC (decomposes)
From ChemInfo on aqueous solutions:
77.7%   193oC
93.0%   279oC
98.0%   327oC
Thanks for all
I suggest you look at NIST. They have a wide range of thermodynamic values on a wide range of gases and liquids.
Dirk Willard
