Temperatures with predefined fields
I am doing a static-general analysis with beam element 2D submitted to fire.
I first do a heat transfer analysis with solid elements 2D in order to know the temperatures in the section.
Then I would like to apply these temperatures to the beam elements sections with the option 'Predefined Fields'.
How could I do to use directly the results file from the heat transfer analysis? Is it possible?
I have tried with the options 'from results or output database file' or 'user-defined' but I always have the error: "Problem during compilation - ifort.exe not found in PATH".
Somebody could help me?
Thanks a lot!
