Theoretical basis to calculate min req cone thickness at small end
I have the COMPRESS build 6162. I calculated a pressure vessel with a transition. The vessel is under full vaccum at 100ºF.
A reviewer of the report questioned the value for the minimum required thickness at small end used in the calculation of expression (4) of Appendix 1-8.
What is the theoretical basis for calculating the minimum required thickness of the cone at small end?
RE: Theoretical basis to calculate min req cone thickness at small end
I recommend that you send your inquiry directly to support at Codeware. See the contact information at www.codeware.com/contact/index.html.
   "Although this forum is monitored by Codeware it is not intended as a venue for technical support and should not be used as the primary means of technical support."
  Tom Barsh
  Codeware Technical Support
  www.codeware.com
