Minimum C02 Pressure and Volume to tap a keg of beer
Please help me settle a bet at work. How many kegs of beer can be pumped with a 20 oz. paintball CO2 tank?
Assume pressure of CO2 tank is 1000 PSI, beer keg is 16 gallons (128 lbs), and lift to spout tap is 36 inches. Volume of paintball tank therefore is ~36 in^3.
Using the potential energy equation PV = mgh my buddy says about 1/8 kegs can be tapped but I say he is "all wet" -- it's more like one (I've seen it)!
He says .128 = 128*36/(1000*36)
Where are we going wrong?
I'll buy you a beer if you can convince me. Thanks!
RE: Minimum C02 Pressure and Volume to tap a keg of beer
he's right, but wth does that have to do with the question?
If the keg was empty, what pressure could be reached using your CO2? Ideal gas law says that at 32F you could pressurize an empty keg to about 64psi if you put 20oz of CO2 into it.
That's enough pressure to dispense, and then some. Even with a large amount of consumed CO2 (as bubbles) you would likely be able to dispense the entire keg.
Let me see if my crystal ball has any idea what you're doing:
Assume pressure of CO2 tank is 1000 PSI, beer keg is 16 gallons (128 lbs), and lift to spout tap is 36 inches. Volume of paintball tank therefore is ~36 in^3. Using the potential energy equation PV = mgh my buddy says about 1/8 kegs can be tapped but I say he is "all wet" -- it's more like one (I've seen it)! He says .128 = 128*36/(1000*36)
0.128 kegs = (128 lbs)*(36*in)/(1000psi*36in3)
so the potential energy to lift a keg 36 inches, divided by whatever (1000psi)*(36in3) is supposed to represent, gives a unitless quantity with some special meaning to you.
http://e
The maximum energy stored using isothermal compression & expansion is about 100ln(P2/P1)kJ/m3, according to wikipedia. Using your 36in3 and 1000psi, one would calculate 0.25kJ or 2210 lbf*in maximum energy storage. 128lbf * 36in gives 4608 lbf*in. This would suggest that you can lift about half a keg 36 inches. Luckily for you, not all the beer is at the very bottom of the keg.
David
I chose the conservation formula to debate my buddy with because it's simple with no english/metric conversions (apparently too simple if we need to be working with the isothermal logarithm equation). Anyway to justify my orginal post:
PVbottle = 1000 psi * 36 in^3 * (number of bottles) = mgh beer = 128 lbf x 36 in
The "unitless quantity" is the number of bottles!
So, I appreciate the input thus far but want to learn why the potential energy equation won't hold here. Perhaps it's the compressibility/themodynamic/heat transfer nature of the fluids at play? Perhaps the PV side doesn't represent the potential energy of the CO2?
I do want to thank the group and specifically Ivymike. But we must be missing something conservation-wise since I've seen this product lift (about exactly one 16 gallon) keg:
http:
Thanks again, cjschwal
1) m*g*h, as you've calculated it, does not seem to accurately represent the potential energy to lift the beer out of a keg
2) P*V for the storage container does not represent the available energy for lifting the beer.
Aside from that, the math should have worked great!
That will get you in the ball park. Then you can refine it with compressibility factors and Henry's Law constants.
David
I've been thinking about this while I drove today and I think I held the wrong thing constant. You'll use a regulator, so you'll keep pressure in the keg constant and
V1/n1=V2/n2. If V1 is the volume of the CO2 hose downstream of the regulator and N1 is number of moles in that volume at 36 inH2O, and n2 is the number of moles in the keg plus the hose when the beer is gone. The difference between n1 and n2 is the number of moles that left the tank. See if this is less than you had in the tank at 1,000 psig. If it is, then calculate a new pressure with those moles gone and try it again. Repeat until the ending pressure in the paintball bottle is less than 36 inH20.
David
Disregarding energy ballances etc, and CO2 absorbed in the liquid:
Since the pressure i the vessel must remain around 16 psi absolute (i think thats low seems to remember that the vessels here in DK are pressureized to around 2-3 barg but OK.
Sorry im going total metirc on you guys now -:
From mu Moullier diagram i get the density of CO2 at 69 barg, 20 deg C==800 kg/m3.
Assuming that the temperature remains constant (=warm beer unless you cool the beer like we do just priou to tapping) then the desity of co2 at just above atmospheric pressure and 20 deg C is around 2 kg/m3. This means that you can fill 400 times the volume at around atmospheric pressure the volume you have at 69 barg (1000 psig). The co2 bullit is 36 cu.in and the keg is 16 gal so the ratio is around 230. So slightly more than one keg can be emtied. Allowing for absorption of CO2 and since i think the pressure is most like somewhat higher then 1 keg seems right.
Best regards
Morten
When you empty the keg - then you replace the beer with co2. So when the keg is empty you now have a keg full of cos - and therefore the mass ballance must work out (also).
I make some important assumptions - and maybe the reason why your simple energy ballance dosnt work out also lies here?
-I assume that the keg absorbs heat fast enough se that the co2 remains at the same temperature. If the pressure let down was isenthalpic then the co would get cold - seperate into an ice and a gas phase and the average density would be much higher.
-I also assume that co2 dosnt absob in the beer. Im not sure if draugh beer is "pre carbosined" or actually carbonised when the co2 pressure is added. That would make some difference - and i havnttaken the time to look at the Henry's law constant and work out the number.
Best regards
Morten
the CO2 in the paintball cannister is liquid, isn't it? Where'd 1000psi come from anyway?
That's why I didn't use P1V1=P2V2 in my initial calculation, and instead used P2 = N.R.T2/V2 (20oz of CO2 provided). I didn't bother counting the volume of hose&bottle, since they only amount to around 1% of the volume of the keg and it was faster to leave them out (omitting them has no important effect on the accuracy of the result for the problem at hand). I assumed that the beer was to be served very cold. My result was Ideal gas law says that at 32F you could pressurize an empty keg to about 64psi if you put 20oz of CO2 into it.
20oz CO2 = 0.567 kg CO2
32F = 273.16K
R = 8314L-kPa/kmol-K
molecular mass of CO2 is 12+16+16 = 48
# k-moles is 0.567/48 = 0.0118
Volume of the keg is 16gal = 60.57L = 0.06057m3
P = nRT/V = 443kPa = 64psi
if you include the CO2 container in the volume, you get a total volume of 16.156gal or 0.06116m3, so your final pressure is 439kPa or 64psi.
I tried to skim the previous posts but missed that you have done the same as I - more or less perhaps even more simple!
I use the Moullier diagram - its tested material more than 70 yeras old! But i was a little quick when reading it - and dont know the reference temperature for the 1000 psig/20 OZ. I think its more like 810 kg/m3 at 20 deg. In order to get to 961 it would have to be fairly close to 0 deg C or 32 deg F. This would mean that the pressure could increase up to around 400 barg (==6000 psig) if the temperature increased to 40 deg C! Maybe these little bullits has a bleed/relief valve?
Best regards Morten
One link is here - it covers the operational area and also has data below the critical points (many other free charts dont).
http://www.union.dk/media/CO2-GB.pdf
http://s
http://www.kegkits.com/carbonation.htm
