in multi axis machining
Hi frdz
Is it possiable to do volume maching useing multiaxis machining option.
For eg attached model part model.
RE: in multi axis machining
What exactly do you mean by "volume machining"?
If you are refering to automatic type operations such as Cavity mill, I believe the answer is No.
J
Hi John
Thanks for your valuable suggestion. I am very thankful to you. But while postin which one i need to select like 3axis mill or 4th axis mill.
What you given is that is XYZ will move. But I want keep "Y" stable and move the "A"(lV)th axis. I mean "A" axis want rotate along the tool. for this how to do.
When I post this file I wnat "A" axis values must come. So how to do this.
thx
Cavity Mill is a fixed axis operation.  The tool axis and thus any 4th axis rotation does not work with cavity milling.
John Joyce
Tata Technologies
1675 Larimer St.
Denver, CO
www.myigetit.com
To answer your question. - No it is not possible to easily do 5 axis volume machining
