Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I wish I knew about this site years ago. It would have saved me a lot of heartaches..."
Geography
gpara (Automotive)
11 May 09 20:03
Can someone give me a volumetric efficiency formula to calculate the cubic feet per minute volume of and engine at a given RPM???
patprimmer (Publican)
11 May 09 20:27
Ummmm
The actual volume of air at ambient temperature amd pressure vs the theoretical displacement.
Like 400 CI 4 stroke displaces 200 CI per turn of the engine in theory, but actually draws in 180 CI per turn is 90% VE
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
BrianPetersen (Mechanical)
11 May 09 21:34
The original poster needs to clarify the question.
"Nominal displacement" (converted to the units of your choice) x half (because of 4 stroke engine) x revolutions per minute x volumetric efficiency under the specific conditions involved = volume rate of flow.
The trouble is that the volumetric efficiency depends on a TON of variables and can often only be estimated. How accurate the estimate needs to be, and how much effort and calculation and simulation needs to be put into producing that estimate, depends on what you are doing with the outcome, and THAT is something you haven't told us.
Helpful Member!  IceStationZebra (Mechanical)
11 May 09 21:37
for a 4 stroke engine:
displacement (cubic inches) x  RPM x vol eff%
---------------------------------------------   =  CFM
                3456
displacement (liters) x  RPM x vol eff%
                56.63369
2 stroke:
                28.31685
ISZ
gpara (Automotive)
12 May 09 8:34
Thanks Guys
Close Box
Join Eng-Tips® Today!
Join Us             Close
