Hex entry into spreadsheets
Is there a formula to convert a hexadecimal string into an integer?
RE: Hex entry into spreadsheets
Under TOOLS-ADDINS make sure the 'ANALYSIS TOOLPAK' is checked.
Then you can access the HEXTODEC converter.
Hope this helps...
It is actually called the "HEX2DEC" function and like meintsi said, it is in the "Analysis ToolPak". If you press F1 while in excel and type "HEX2DEC", excel help will tell you the steps to take.
Good Luck
jproj
Thanks jproj
