GRIP: INTSEC/ ...help/example needed
Folks,
It's been a while, and I'm apparently a bit rusty. I'm trying to write a grip that will develop a series of planes (all on z-axis), and generate cross-sections of a user picked sheet body (via ident/). I'm generating the planes, and picking the sheet body ok... but am failing when trying to use the INTSEC/.
<code>
ENTITY/PL(200),$ $$ ARRAY FOR PLANES
SHEET1,$ $$ SHEET FOR SECTIONING
SECTLINES(100) $$ ARRAY FOR SECTION LINES
DO/L41:,J,1,100,1
SECTLINES(J)=INTSEC/SHEET1,WITH,PL(J)
</code>
routine compiles ok...
runtime error: "attempt to use an object variable to which no object has been assigned."
Ideas? Help is much appreciated and TIA.
<code>
DO/L41:,J,1,100,1
</code>
SS
CAD should pay for itself, shouldn't it?
RE: GRIP: INTSEC/ ...help/example needed
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Cypress, CA
http://www.siemens.com/plm
I believe so (but could be wrong...). I'm pulling an expression from NX for the shrink value..
<code>
$$ pulling shrink value from NX part exp
$$ ...actual value = 1.012
SL=REGF('SHRINKZ')
$$ M== ht of sect value * shrink value
M=(Z(I)*SL)
$$ create plane for cutting section on AF
PL(I)=PLANE/XYPLAN,M
</code>
The planes are created at the correct heights...
SS
$$ section plane generator
$$<code>
NUMBER/R
ENTITY/PL(200) $$ ARRAY FOR PLANES
SHEET1,$ SHEET FOR SECTIONING
DO/L40:,J,1,100
PL(J)=PLANE/XYPLAN,.1*J
L40:
IDENT/'SELECT SURFACE TO INTERSECT',SHEET1,R
DO/L41:,J,1,100
L41:
$$</code>
HALT
