Locomotive Engine Transportation
I have a locomotive engine of 50,000 lbs (25 tons) to transport. I plan on transporting it using slings. I want there to be a motor with pneumatic wheels to transport on dirt roads. It can either be lifted (straddle carrier) or placed on a flat bed (transfer cart).
Would you have any ideas of something I could use? The straddle carrier are way too big and the transfer carts have a steel wheels. Is there a product on the market for this?
RE: Locomotive Engine Transportation
I live near a preserved Steam railway and they frequently bring in visiting locos on a flatbed low-loader and winch them up/down the tail ramp, straight onto a suitable spur of track. Fifty to eighty plus tons is quite common, but they tend to avoud too much "off-roading".  They have used a slings and a fairly large mobile crane where access is limited.
I would check out similar organisations in your area or specialist heavy hauliers.
http://www.wsr.org.uk/cgi-bin/gallery.cgi?h=Picture+Search&p=low+loader
TenPenny
EXCELLENT! but where is the tractorbigcheeks
Steven C
Senior Member
ThirdPartyInspections.com
eyec,
It's called a self propelled modular transporter. There is no tractor as, depending on the configuration, either all wheels drive and steer or all steer and a preset arrangement (like every other row) also drive.
Thanks SincoTC & Tenpenny!!
In the end, we will be going with a transfer cart with steel wheels that are made to go on railway tracks.
Everything is good for now.
Thank you once again.
ps. Tenpenny: That is one crazy machine!!
You can contact one of the trucking companies that transport logging equipment to logging sites on logging roads. 25 tons is not a lot for a rig that transports large bulldozers. We had a 60 ton transformer delivered on a similar rig. They are called "low bed trailers".
Bill
"Why not the best?"
Jimmy Carter
50,000 lbs is just about what the payload of the typical 18 wheeler in the USA transports, so the weight itself is not the issue.  I suspect it is the height that is the problem and that might then dictate the straddle carrier or the low bed type trailer.  There is one called a double drop deck that gets about as low as can be done.  The biggest (in every category, weight, height, width and length) load I ever had to have transported weighed 365,000 lb and was 57 feet long, 15 feet wide and 19 feet tall (or was it 15 high and 19 wide-I can't remember.  That definitely dictated specialized equipment.  The rig itself was a permit load just to travel empty to load my load-it exceeded 80K lbs.
Bill is right in recommending carriers that deal with the logging industry.  Find a website for Dallas and Mavis if they still exist (and if you are in the states).  They thrived on that type of stuff.
rmw
It'd just be another load on a lowboy trailer in a lot of the country.
