Vane Shear Test
Vane Shear Test
In the Vane Shear Test. How do you calculate\Control the Torque (T). Also, in the equations to calculate Cu, what is Beta. After you calculate Cu from the test. how do you calculate the bearing pressure. Thanks
RE: Vane Shear Test
RE: Vane Shear Test
You will find many references.
As for bearing capacity calcs, that probably is not something that anyone can answer without much more info on your job and even then I doubt that you will find a suitable answer here.
