Syngas Turbine Output
Can anyone let me know where I am going wrong. I am doing a calc to find how much power my refinery syngas will produce and I get some astronomical numbers.
Syngas
LHV 41.5 MJ/nM3 or 43.5 MJ/kg
Density 0.95 kg/nM3
Quantity 11,200 tonne/day
Any help appreciated
SD
Syngas
Density 0.95 kg/nM3
SD
RE: Syngas Turbine Output
Furthermore, more input data is required to answer you question adequately and fuel either HHV and/or LHV will just indicate the specific fuel consumption or just fuel consumption ...
For example, compression pressure ratio, gas turbine inlet temperature, mass flow rate etc.
Here are a few representative plots describing the gas turbine (Brayton Cycle) operation.
http://www.engineering-4e.com
I can report that for 1 [kg/s] of air, there should be 0.015 [kg/s] of fuel (natural gas/methane). Gas turbine inlet conditions are 15 [atm] and 1,500] resulting in getting 462 [kW] as the power output. Daily fuel requirements are as follows: 1,296 [kg/day].
I have to admit that your final number in terms of the fuel consumption is no longer as strange as I initially thought ...
I would suggest that gas turbine operating conditions be spelled out for the purpose of good engineering comparison ...
No problem.
The numbers are huge when it comes to the fuel requirements on daily basis for the given thermal input and power output basis.
Again, for next time just provide some information on what the other input data are.
In the end, I was able to put the puzzle together and your numbers are OK ...
This was a good and interesting "assignment" for me -- usually I do calculations for 1 [kg/s] of air getting into a gas turbine power cycle ...
Thanks!
