asme section viii div i code changes after 1979
hi all,
i am working in a refinery which was shutdown in 1980 where i am working of refurbishment of the pressure vessles which almost everyone is manufactured in 1950 and 1960's what are the code changes in asme pressure vessel code since 1970 so that i can evaluate what new criteria the pressure vessels need to meet.
thank u.
thank u.
RE: asme section viii div i code changes after 1979
What makes you think the vessels need to meet any new criteria?
And do you really think that the changes to the code can be summarized on an internet post? Have you seen a 1950's era Section VIII and compared it with a 2000's era Section VIII Div. 1? Slight change in volume of paper, and that's excluding the fact that allowable stress info was relocated into a different Section.
jt
Restarting a refinery that has been mothballed for almost 30 years is a significant task, and will require the expertise of the world's foremost experts. Find them and pay them what you believe their answer is worth.
