AutoCAD circle sub-menu
HELP!   Some setting in AutoCAD 2009 got changed on me and I'm hoping someone knows the quick answer - I used to be able to type "CI", hit the spacebar, then hit an arrow key to get the submenu for drawing a circle.
Now I get nothing when hitting an arrow key.  Anyone have a clue?
Ralph
Structures Consulting
Northeast USA
RE: AutoCAD circle sub-menu
Try just hitting "c" spacebar/enter.
I have Circle shortened to "CI".
Spacebar or Enter does the same thing.
No submenu appears on the screen near the cross-hairs.
Ralph
Northeast USA
If your looking for the command to be typed in on the screen and not in the command line.  Check to see if dynamic is turned on.  If thats not it then you might want to type in "cuiload" and unload your ACAD.cui file and re-load it.  The ACAD.cui file might also be corrupeted in which case you will have to do a repair.
ProDraftsman:   Thanks for the help.  I must have inadvertently clicked on the DYN toggle at the lower left of the screen.
Ralph
Northeast USA
