Instrument Gas Heating - Heat Pipe?
I'm designing an instrument gas system for a natural gas metering station. Its in a remote Australian location and requires gas to actuate some valves. The supply pipeline operates at up to 12,000 kPa and the instrument gas is typically 800 kPa so there's lots of JT cooling but a very low flow rate.
The client is keen on a "Heat Pipe" system to help use ambient heat recovery. I'm familiar with the concept, but have never seen it used on instrument gas supplies. I've looked at normal ambient heat recovery (min ambient is 3°C), ground heat recovery (14°C) and heat tracing.
The client is keen to show how clever he is though. Has anyone used a heat pipe system on instrument gas? If so, how well did it work and who supplies them?
Thanks in advance
Clinton
Thanks in advance
Clinton
RE: Instrument Gas Heating - Heat Pipe?
http://www
