newline character doesnt work?
I use gfortran on cygwin and in a simple code like:
i get:
firstnamelastname
instead of
firstname
lastname
i also tried
and
with no results.
What can be the problem??
CODE
program test
open(50,file='test.dat')
write(50,'(A)') 'firstname'
write(50,'(A)') 'lastname'
close(50)
end
close(50)
end
i get:
firstnamelastname
instead of
firstname
lastname
i also tried
CODE
write(50,'(A/)') 'firstname'
write(50,'(A/)') 'lastname'
CODE
write(50,'(A)',ADVANCE='YES') 'firstname'
RE: newline character doesnt work?
but not when i print in a file .dat or .txt
CODE
If I am not mistaken, it should work for you -- please check it out ...
http://www.engineering-4e.com
The // is a concatenation operator
and writeln (or writenl) is not recognized by my compiler
yes it is! it is needed to concatenate char(13) which is carriage return and char(10) which is linefeed to the end of the line, as is the case for text files in MS Dos and Windows.
"writeln (or writenl) is not recognized by my compiler"
because neither is Fortran !
What are you using to view the output file with??
In my opinion, it should not be a difficult problem to solve, but it is.
My suggestion is to do a Google search and try to find a source for gfortran and its commands with some working examples ...
and the result remains the same
In all fortran manuals i see,
slash / begins a new line!!
This is a Fortran forum, not a guess the answer quiz!
CODE
write(6 ,FMT='(I3,/)') 111
WRITE(6 ,FMT='(I3,/)') 222
write(50,FMT='(I3,/)') 111
WRITE(50,FMT='(I3,/)') 222
close(50)
end
111
222
but in the dat file i see:
111222
With what are you viewing the file "test.dat" ?
- Steve
Notepad will not recognise a "unix" formatted file with just a linefeed character (char(10) as above) at the end of each line as a delimiter. Notepad being Microsoft expects to see a carriage return followed by a linefeed (char(13 and char(10)), to signify a new line.
If you use an editor like PFE32 it will recognise and distinguish between MS or unix text files , (displaying the file format in a box), I'm sure there are other editors that will do likewise.
Gfortran on cygwin means it has been ported from linux to run on windows, that's probably your problem. Try using the windows version of g95 instead, it works fine.
I only have a version of Fortran77 complier installed on my computer.
Now, I can say that you had an answer to the question and/or problem, but there was a file reading issue getting in the way -- you recognized what the issue was ...
In my opinion, with computer work, there is always something that gets in one's way no matter how simple and obvious the problem is -- there is always more to it than it should be ...
Thanks!
but since i dont want to use microsoft editor like MSword u mentioned..
Do u know an editor i can call with cygwin that will display the result correctly?
http://w
Thanx
