Hole Wizard-Centerlines
Is there a workaround for the hole wizard and refencing centerlines & dimensions on a drawing? I have a hole pattern with c'sink holes and centerlines on my drawing defining those holes, and everytime I edit the hole wizard, the centerlines on my drawing are now dangling. I have to now erased the centerlines and dimensions that are link to it, and have to re-create everything.
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2009 SP 3.0
Dell 490 XP Pro SP 2
Xeon CPU 3.00 GHz 3.00 GB of RAM
nVida Quadro FX 3450 512 MB
3D Connexion-SpaceExplorer
RE: Hole Wizard-Centerlines
Considering the other problem you mention in thread559-244602: Document Properties-Revision Blocks, I would conclude you have an install problem ... or software conflict ... or hardware conflict ... or .....
