Low-ratio gearboxes
Low-ratio gearboxes
I'm looking for a standard ANSI/AGMA type gearbox providing a speed reduction ratio of approx 1.5:1. Rated power range between 5-20 kW. Input speed = 3600 rpm.
In-line shaft design is strongly preferred over parallel shaft or right angle, which I know can handle lower ratios. I strongly prefer to avoid pulley and belt drive.
Gearbox will be mounted close-coupled with an electric motor.
Any suggestions?
Any suggestions?
