Cylinder head design in solidworks, help!!!
Hi!
I am trying to design a single cylinder head for a 250 racing engine.
I am using solidworks, i have make some drawing but i can not get good results.
External shape is not problem but i want to get all internal shapes (water cavities)
now i am trying to design all head shapes with surfaces and then use "thinken" operation to make a 4 or 5mm wall to all head but it is really dificult because solidworks give me erros when 5mm wall intesect with himself (very poblably).
Please any idea is welcommed!!!
pictures: http://www.arbizuracing.com/index_gp.html
jlcortex
jlcortex
RE: Cylinder head design in solidworks, help!!!
Insert and position them into the cylinder head part model
Use the Combine tool to create the internal voids
Jeff Mowry
www.industrialdesignhaus.com
A people governed by fear cannot value freedom.
Also, if you are intending to machine the head from a solid block of material, then using regular cut-extrudes to simulate the machining process would give the required result.
