Natural gas well
Natural gas well
My father in law has a gas well on his property and would like to use it as a fuel source for his pov.He contacted Fuelmaker regarding refueling equipment and at their request sent them a gas sample from the well for analysis. According to Fuelmaker the gas analyzed is not suitable with their equipment due to high nitrogen, propane and ethane levels.
Sample numbers:
Methane 81.47
Ethane 7.20
Propane 3.33
Nitrogen 6.62
What would be the most efficient and cost effective way to clean up the raw gas for use in a CNG vehicle?
Thank You
Sample numbers:
Methane 81.47
Ethane 7.20
Propane 3.33
Nitrogen 6.62
Thank You
RE: Natural gas well
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
If you took the water out, the gas would be perfectly fine if you set up the feul management system to recognize the composition. I burn gas just like what you show in our 2000 HP gas engines with no problem. But to sell commercially, you have to meet SAE specs. The LNG industry has approached SAE to raise the ethane to 3%.
I'd guess you also have 1.5% Butanes, .5% pentanes and .5% gasoline in the gas too.
