Calculating material around internal threads
How do you determine if there is enough material beyond threads of a tapped hole?
We are fabricating our own swingbolt closures, similar to Tube-Turns T-Bolt closure, and need to prove the pin diameter is sufficient for the tapped hole that goes through the diameter of the pin.
Any help would be greatly appreciated.
RE: Calculating material around internal threads
