Fire Rating of Concrete-Filled HSS Column Sections
I am designing exposed exterior HSS18.000x0.500 columns to support a roof above an interior atrium space. Since the columns are visually exposed and also exposed to the elements, I am reluctant to recommend intumescent piant for fire protection as it will experience UV degradation over time. I have recommended filling the columns with concrete as an alternate to intumescent piant; then simply painting the columns a weather resistant grade of paint.
Can some one direct me to where/how I can qualify the fire rating of the resultant composite column sections?
Thanks, in advance.
Thanks, in advance.
RE: Fire Rating of Concrete-Filled HSS Column Sections
Have you tried searching ACI publications?
Ralph
Structures Consulting
Northeast USA
How about dropping a cage of rebar in there and making it a concrete column with steel cladding?
It shall be up by tomorrow I guess.
