Process consultan
Process consultan
Greetings to all.
I would like someone to clarify whether from the standpoint of processes can be used with a valve JT effect for the following process:
The gas that comes from dehydration (0.5 lb / MM) is cooled in two stages (30 to 120 º F, 30 to 5 º F), then goes to a separator. The current ceiling for the sale of gas compressors to 1120 psi. Liquids can stop them through a JT valve and expanded to 350 psi and into a tower and Desetanizadora stabilization? or it would be through control valves?.
The top of the tower off gas recompression and mixing with residual gas. The bottom goes to LGN Fraccionamiento.
My question stems from the fact that I have always viewed JT valves in gas. No liquids.
thanks
thanks
RE: Process consultan
thread124-132825: JOULE-THOMSON EFFECT puede ser útil.
As dcasto says - theres no such thing as a JT valve, or a flow control valve or a pressure control valves - they are all just valves!
Best regards
Morten
