Suppliers of 50kW 70 krpm motor and controller
I'm trying to buy a motor and speed controller for an axial flow compressor test rig. ideally I'd like 50kW which should drive it to 70,000 rpm but I'd consider anything above 8kW and 30,000 rpm. I've spent a couple of days with Google but haven't really come up with anything. Any ideas would be appreciated. Thanks
RE: Suppliers of 50kW 70 krpm motor and controller
you can get an idea from this US supplier http://www.dynospindles.com/index.html
TygerDawg
Blue Technik LLC
Virtuoso Robotics Engineering
www.bluetechnik.com
Vacon AC Drives For High Speed Applications
http://ww
I found some Siemens information also. The information I found was much higher power and lower RPM for pipeline compressors, but they probably have something in your Power / RPM range also.
Kompositprodukter does develop things like that.
Gunnar Englund
www.gke.org
http://www.reuland.com/
