Calculation of tubing head pressure from reservoir pressure
Some time ago I had an Excel spreadsheet which calculated the surface pressure in a dry gas well from the reservoir pressure/depth and gas composition. I have now lost it, does anyone have anything similar out there?
RE: Calculation of tubing head pressure from reservoir pressure
The pressure traverse from the surface through the wellbore tubulars is complex, but well documented. The pressure traverse from the end of the tubing and through the near-wellbore reservoir rock is even more complex and is absolutely well/reservoir dependent. Every well has different "skin", different amounts of anisotropy, different fracture half-length, and different occurrence of natural fractures. Generalizing that into a spreadsheet seems to be the easiest part of the process--developing a generalized set of equations that has broad applicability is something that software companies have spent billions of dollars on over the decades.
Is is possible that you have substituted the term "reservoir pressure" for "flowing bottomhole pressure"? If so, the equations are well known and published in many places.
David
David
